Oil sump plug wont budge
Joe Wright
Re: Oil sump plug wont budge
#11 Post by Joe Wright »
Okay. Thanks
#12 Post by johnnydog »
I would have thought that a engine sump plug would have been taken out a bit more frequently than a gearbox drain plug, and therefore it ought to come out without the effort described above. I think that as long as the Stilsons are of the correct size (not overly big) and the jaws are adjusted correctly, you will shift it.
Joe Wright
#13 Post by Joe Wright »
Hello everyone. Stillsons got it. The head was destroyed obviously been an issue for a while. Problem now is the oil filter. That wont move so I'm going to go and by a removal tool. I've tried all the other tricks like a belt etc. Hopefully I'll get there. This has been one long winded oil change.
Thanks for your help.
Joe
Joe Wright
#14 Post by Joe Wright »
johnnydog wrote: Sun May 10, 2020 12:03 pm Here's a picture of the magnetic type - it is a 3/8 BSP thread according to CW, but he has no stock.
Thankyou
#15 Post by johnnydog »
Joe Wright wrote: Mon May 11, 2020 5:57 am Hello everyone. Stillsons got it. The head was destroyed obviously been an issue for a while. Problem now is the oil filter. That wont move so I'm going to go and by a removal tool. I've tried all the other tricks like a belt etc. Hopefully I'll get there. This has been one long winded oil change.
Joe
Glad you got sorted with the Stilsons! Is it the standard paper filter horizontally on the block, or a screw on type from an aluminium adaptor?
It sounds like you have a screw on type. On reassembly they only need to be barely hand tight as they seem to tighten up over time and are then tighter to remove come next oil change. A smear of oil on the seal to adaptor face is a good idea when fitting the new filter, but this can lead to overtightening of the filter as the seal to adaptor face moves easier when contact is made (if that makes sense?!?)
Joe Wright
#16 Post by Joe Wright »
Hello all. What a palava. As mentioned before I finally got the sump plug out but my twist off oil filter was stuck. Borrowed some oil filter removal tools and after about five minutes I put a hole in the filter. Quickly got it to the mechanics just around the corner and my new oil had all but gone.
Luckily the mechanic got the old filter off and refilled, put the new oil and filter on.
All done now but a bit of a nightmare. Definitely going to change the sump plug on the next oil change.
Now time for a coolant flush.
Thanks again for all your help.
#17 Post by Mike Stevens »
For information, the gearbox drain plug as fitted has a small magnet to collect swarf and has the same thread as the engine sump plug. It also has a 'proper' hex head!
So if you can get hold of one of those, it's an easy fix.
Joe Wright
#18 Post by Joe Wright »
Ahh excellent. Thankyou
trolleybus
#19 Post by trolleybus »
Alec wrote: Sun May 10, 2020 7:02 am You can buy replacement plugs with a hexagon inset so an allen key can be used but you won't find them everywhere,
Best advice, I recently fitted one as a drain plug to a diff I rebuilt. Then I purchased four moor and replaced the two in the gearbox, the sump, and the diff input.
I now use an allen key fitting for a socket wrench which gives me a good leaver to tighten/undo them. They are readily available at my local bearing supplier in Australia and don't cost a lot. If you fancy a magnetic one wrap some insulated wire around the plug and attach to a small battery, magnetise the the hex one.
Bernard (Australia)
1977 2500 TC Auto EFI
1956 TR3 since 1980
Joe Wright
#20 Post by Joe Wright »
Thanks for the advice. Yes I am definitely going to be changing them.
