So, removed all the paint in the area back to bare metal, scrubbed out the small little pock marks of r*st and painted with phosphoric acid before gently abrading and applying several light coats of zinc primer of the self etch variety. Left this to dry over 2 days, rubbed down with ever finer wet n dry, mixed up some paint to get a close match using pattern French Blue from a professional paint supplier with a little white tint to match the aged and weather bleached original paint and put on 3 light coats. Two more sets of 3 coats over the course of 20 minutes or so, waiting for the underlying paint to just go off before applying more and feeling rather pleased with myself that the colour match is almost perfect and the finish as good as Canley number 1 paint shop, even down to matching the slight orange peel effect.
Cleaned everything up (takes longer than the actual painting) stinking out the neighbourhood with the fumes of gunwash. Then I noticed two sags in the paint
So I'm going to have to let it harden for a week or two and attack it in the approved way to remove the sag.
Kevin
