Page 1 of 1
Twin SU HS6 Wanted
Posted: Sun Dec 19, 2021 8:39 pm
by Sal
Hello there,
If any one knows of a good set for sale that are not silly money please do let me know
Sal
Re: Twin SU HS6 Wanted
Posted: Mon Dec 20, 2021 8:51 pm
by johnnydog
I may have a used pair of HS6's, but will have to check and get back to you. Do you want just the carbs, or the inlet manifold as well?
Posted: Mon Dec 27, 2021 4:43 pm
by Sal
Hi Johnny, sorry for the delay
I have a manifold for my HS4’s so I guess that’s the same so if it is then just the carbs will do
I will PM you as well
Sal
Posted: Mon Dec 27, 2021 9:56 pm
by johnnydog
Hi Sal,
I thought SU HS4s were only a two stud fitting to the inlet manifold, whereas HS6s were a four stud fitting?
Maybe you could just check to confirm, but I will have the 4 stud inlet manifold if needed with the HS6s which would be a straight swap.
Posted: Mon Dec 27, 2021 11:02 pm
by Sal
Yes you’re right my HS4’s are 2 stud fitting so I’ll need the manifold as well and if they are complete with linkage even better
Sal
Posted: Tue Dec 28, 2021 9:03 pm
by johnnydog
Sent you a pm Sal
