Twin SU HS6 Wanted
Sal
Twin SU HS6 Wanted
#1 Post by Sal »
Hello there,
If any one knows of a good set for sale that are not silly money please do let me know
Sal
Re: Twin SU HS6 Wanted
#2 Post by johnnydog »
I may have a used pair of HS6's, but will have to check and get back to you. Do you want just the carbs, or the inlet manifold as well?
Sal
#3 Post by Sal »
Hi Johnny, sorry for the delay
I have a manifold for my HS4’s so I guess that’s the same so if it is then just the carbs will do
I will PM you as well
Sal
#4 Post by johnnydog »
Hi Sal,
I thought SU HS4s were only a two stud fitting to the inlet manifold, whereas HS6s were a four stud fitting?
Maybe you could just check to confirm, but I will have the 4 stud inlet manifold if needed with the HS6s which would be a straight swap.
Sal
#5 Post by Sal »
Yes you’re right my HS4’s are 2 stud fitting so I’ll need the manifold as well and if they are complete with linkage even better
Sal
#6 Post by johnnydog »
Sent you a pm Sal
