Page 1 of 1
Tr6 driveshaft vs 2500 driveshaft
Posted: Tue Oct 07, 2014 11:43 am
by e.p.j.
I have seen a nice solution for tr6 driveshaft with cv and a new hub (limora.com). I was wondering if it is possible to mount these on an 2500 estate?
Does any one have some experience with these conversions ?
Also Weslake has an BMW diff conversion for the stag.
But doesn't react on mine mails.
Who has experience with Weslake automotive?
Edwin
Re: Tr6 driveshaft vs 2500 driveshaft
Posted: Tue Oct 07, 2014 1:18 pm
by Andy Thompson
Look at goodparts (USA based)
They do an Uprated hub and CV shaft conversion
https://www.goodparts.com/shop/index.ph ... ductID=823
Posted: Tue Oct 07, 2014 3:59 pm
by leesellars
Tr6 Shafts are a different lenth than saloon
Posted: Wed Oct 08, 2014 9:25 am
by Thorsten
Hi Edwin,
as Lee pointed out the TR shafts are shorter than saloon shafts.
If you are referring to a Mk2 Estate you could use the CV driveshafts offered for the Stag which are the correct length. I am using these CV driveshafts since 2004 (approx. 60,000 kms) in my 2000 Mk2 Estate and 2.5 PI without a problem so far. These shafts were from TR Nord, a Triumph workshop near Hamburg, Germany. They invented these driveshafts for the TR roadsters and later on assembled a small batch for the Stag as well.
As far as I know, Limora initially distributed the TR Nord items but are offering their own product now (which doesn't necessarily makes it better, I guess).
Their hompage is
http://www.tr-nord.de/ only in German, though.
Kind regards
Thorsten
Posted: Wed Oct 08, 2014 4:39 pm
by e.p.j.
Thanks every one,
I will send some mails to the mentioned enterprises.
Will keep you informed
Posted: Thu Nov 06, 2014 11:54 am
by e.p.j.
Hi,
I found a set from limora Berlin.
I have mounted them a week a go and I am very happy with the handling of the car.
It doesn't tweak any more when accelerating hard in a bent and then changing gears.
I Still have a lot of rumbling in the rear. So that will mean another diff.
Thanks every one
