Hi Gavin,
You can of course try running it with the rocker cover off. Yes, it makes a mess, but you will soon see if there\'s any oil squirting around. In my experience, the oil just drips off the rocker shaft, runs all over the top of the head and then down the drain holes on the LH side of the head. Oh yes, and down the back too as the engine slopes that way. If your rocker cover gasket is stuck to the head, it will act as a dam for a short length of time.
If you have positive crankcase breathing into the inlet manifold, you\'ll have to block that up or the engine won\'t want to start.
Just a wee thought.
Why am I getting an oil leak there?
Hi Gavin, just had the same thing with mine, I found that there is an oil feed/ well at the back of the head. The head gasket had fractured and the oil was leaking from there down the back and the side of the engine,it leak\'s outwards not inwards so there are no symptom\'s of the head gasket gone. So had to take the head off, put new gasket on, no oil leak now. <IMG>
on the old gasket you could see the fracture in the gasket.
pete
pete
- Umquat
After yesterdays posts I stopped about half way to work (having checked that the join was dry this morning). I think you guys might be right. It certainly seemed to be more noticably wet at the back of the block than nearer the front. Anyway, its half term next week, I have Tuesday free to work on the car, and a complete head gasket set on order, so if it arrives in time, I\'ll whip the head off and see whats going on. Thanks for all the advice once again.<br><br>Regards<br><br>Gavin<br>
- David Withers
