Camshaft options
Llessur
Camshaft options
#1 Post by Llessur »
I'm (still) in the process of rebuilding the engine from my 2500S and things are finally starting to take shape.
My camshaft showed some light pitting to a couple of the lobes so I've sent it off to a reputable place in Victoria (Clive Cams) for inspection and hopefully a re-grind.
The cam is a stock 307621 and the head is part number 219021 which is identical (except for the EGR port being drilled for the Australian market - not that I've got one fitted) to the 219016 head. The block is number MM44232HEA. Pistons are +20 thou, bearing shells are all +10 thou. Everything else about the engine and head is standard. Both have had a very light skim to their mating surfaces, the recesses for the head gasket rings on the block are still well within spec. I'll be running rebuilt twin HS6s.
Providing my camshaft is assessed as good for a regrind, should I stick with the 307621 profile would it be worth getting it re-profiled to 308778 specs? Am I more likely to breach the hardening if I go with a new profile as opposed to keeping original?
I can get a 308778 ground from a new billet but this is around 4x the price of a re-grind.
All thoughts welcome :)
1977 2500S - White
Re: Camshaft options
#2 Post by johnnydog »
I would be tempted to contact Chris Witor for his opinion. He is probably one of the most knowledgeable about the benefits of the various camshafts in our engines.
