Who drives what?
- kevinw
It\'s all getting a bit hairy - the \'6 developed a bit of a misfire a few weeks ago. Having replaced all the ignition components, including distributor, it is oiling up plugs 3 & 4. The injectors have been tested for volume and pattern and are all OK, so a compression test was done. 5 years ago, each cylinder was reading over 200 psi, now we have less than 170. The conclusion is that the valves are not seating properly and the valve guides may be worn. So, currently, the head is off and is donating its springs and collets to an exchange head that has been hardened and is having good quality valves / guides / whatever fitted. This is hopefully going back on tomorrow and we should be back on the road early next week. There\'s also a new fuel pump to go on as ours has a small leak and sometimes makes horrible noises and, I\'m told, isn\'t quite the right type. It\'s also had, in the course of the past few months a new steering rack, the brakes rebuilt and all the UJ\'s from the gearbox backwards replaced (plus splines inspected). I\'ve got a couple of days next week to put a few hundred miles on it before we depart next Monday for a leisurely journey to Rimini. We do have a fall back plan - if I\'d owned the 2000 for a bit longer, I might have been tempted to take that - but otherwise we will have to take the VW Sharan and put a sticker in the back saying something like \"My other car is a Triumph\". You will recognise me quite easily in Rimini - I\'m the one that (allegedly) looks like Dilbert\'s pointy-haired boss!
Kevin
Kevin
- Umquat
I think that you should post a picture of yourself to confirm this likeness <img>.<br><br>We always get the Dilbert calendar every year at work, and I have often heard it described as Dilbert World. The cartoons are hilarious simply because so many of them are sooooooo true to life!<br><br>Regards<br><br>Gavin<br>
- Allen Walker
Back to the cars:
<br>1978 Mini Clubman Estate, brown, subframes gone, crablike on road, fun.
<br>1984 Toyota Tercel 1.3, metallic blue, dull and slow
<br>1987 Rover 213S, absolutely knackered, was probably a nice drive once
<br>1989 Seat Ibiza 1.5 GLS - great, good performance, v. heavy steering
<br>1996 Nissan Micra 1.0 - first and only new car, amazing performance for
<br>1 litre, boring.
<br>1966 MG Midget MkII - good cars, chuckable, mine was rusty
<br>19?? Fiat Uno - crap and knackered
<br>1997 Fiat Punto - good, wore out, expensive to fix
<br>1996 Vauxhall Corsa 1.2 Euro \'96 Ed. good looking car, slow, handled
<br>badly, very reliable and cheap to service
<br>2003 Honda Civic 1.6SE - current family wagon, good engine, capacious
<br>2002 Vauxhall Corsa 1.7 Turbo Diesel - current eco warrior, 60+ mpg
<br>1976 Triumph 2500S - current classic, no MoT at mo, due for fixing.
- Alan Chatterton
- kevinw
I\'ll answer 2 posts at once:
1. Picture - have a look at <A>www.dilbert.com</A> - I\'m the bloke in the blue suit, bald head and sticky up hair. I will admit I don\'t wear a suit very often, but am bald and my hair does stick up in cones when it needs a cut...
2. Trip to Rimini - well, ours isn\'t a direct route, but going it is Dunkirk, Cambrai, Nancy, Luzern, St Gotthard Pass, Piacenza, return is Modena, Ivrea, St Bernard Pass (Italian Job Route) Montreux, Besancon, Laon, Dunkirk. According to Charlie Croker, it is 2 hours from Turin to Geneva in a fast car...
Dunkirk route is purely because the ferry is so cheap if booked in advance. Sensibly, we\'d go from Portsmouth as we live less than 15 minutes from the terminal. If in a hurry, it is 2 overnight stops - you could do it with just one, but it a bit of an endurance test.
At the current rate, we may either be going in the 2000 (although I\'m not sure that I\'m brave enough to do that yet as the journey from Esses to Hampshire was seemingly its longest run in 32 years), or in a VW Sharan with a sticker in the back saying \"my other car has broken down\"
Kevin
Kevin
French rep
Hello,
Sharing Alan\'s problem as a car addict :
I have add to my fleet a pair of MGB (64,67, rusty bits), a pair of MGBGT (67,72), a pair of Mini (60, 71), a pair of Spitty (Mk2 and 1500FH) and soon a pair of Stag (had already a 71\' one).
Everything work in pair <IMG> ?
According to my insurances cars list, i have more than 50 cars and bikes now <IMG>....
Cheers, Chris.
Cheers, Chris.
French rep
