Will 205 tyres fit?
Brian
#1 Post by Brian »
Does anyone know if 205/70x14 tyres will fit a MK2 without fouling anywhere? Thanks!
#2 Post by Alan Chatterton »
Yes, they fitted mine ok, but fouled on my mates. Need to check the rear shocks and the front tie bar/anti roll bar as this is where they may rub.
Consider using 205/65/14 not 70 profile. The profile number is the % of the width as the height, so the wider you go, the lower profile you need to keep a sensible rolling radius.
I use 195/65/14 and they are just fine and dandy. On my PI I am using 195/60/15 but both the same rolling radius.
Brian
#3 Post by Brian »
Thanks Alan. I may settle for 195s as I would hate to buy a set of tyres to find that they foul the car. Off to see how much room I\'ve got...
