Speedo drive oil seal
smithyiow4
#1 Post by smithyiow4 »
Hi all need to change my speedo drive oil seals is it just undo bolt drop it out then refit or am I missing something I guess all the oil will come out too ta john
Re: Speedo drive oil seal
#2 Post by johnnydog »
Yes, when you remove the speedo cable, and take out the speedo drive, you will lose some gearbox oil - quite a bit actually if the car is level on a ramp, and it comes out rapidly!
If you can jack the car up front and back just on the side of the speedo drive, it should minimise the amount of oil lost.
smithyiow4
#3 Post by smithyiow4 »
Ok great thanks
