Page 1 of 1
Converting MK2 to Tandem Master Cylidner
Posted: Sun May 07, 2023 8:34 am
by GinettaG15
my car is a RHD MK2 with its original single -circuit brake system.
what main parts would i need to convert to a dual circuit. can is just source / install the Tandem-Master used in export versions of the MK2?
Re: Converting MK2 to Tandem Master Cylidner
Posted: Sun May 07, 2023 6:02 pm
by iani
I used a Stag M/cyl, need to replace the 4-way union on the inner wing with a 3-way and run a rear brake line down to splice into the rear circuit. I did replace all components with Stag parts however, including the Servo.
Posted: Sun May 07, 2023 7:37 pm
by GinettaG15
ok....the question is: is it "just" a direct swap of the cylinders, without using the stag´s servo?
Posted: Sun May 07, 2023 7:55 pm
by iani
GinettaG15 wrote: Sun May 07, 2023 7:37 pm ok....the question is: is it "just" a direct swap of the cylinders, without using the stag´s servo?
You will have to change the 4-way union to a 3-way union and connect the rear circuit from the m/cyl to the rear circuit.
Posted: Tue May 09, 2023 7:17 pm
by GinettaG15
iani wrote: Sun May 07, 2023 7:55 pm
thats obviously clear... :wink:
so i just buy the tandem, change some piping and thats it? brake balance won´t be negatively effected (over-braking at rear?)
Posted: Sun May 21, 2023 7:26 pm
by GinettaG15
https://rimmerbros.com/Item--i-GRID008720
spring and plunger on servo side are not present at the single-cylinder.
7/8" bore diamter looks 2mm bigger than the single one?
Posted: Sun Jun 25, 2023 7:35 pm
by Mikengard
Did you get an answer to this question? Can you use the stock, single system servo, or do you need to install the dual system servo?
