Anticipation of being able to actually drive it again (and legally i might add! ) after such a long time and with so much work being done was high as to be expected !!!
It was certainly nice to get behind the wheel again, and with my youngest lad who has been waiting so long for his maiden voyage - never have I seen him smile so much... and all the onlookers.., pointing, staring,wondering what the h**l that is
So without waffling on, ironically the teething issues we found were nothing to do with any of the work that has been carried out. Firstly, it would seem the water pump has had enough at 47 and has decided to leak - not bothered there as easy enough fix and the part is available.
The second issue however is more worrying - the BW 35 is not changing up in D. I know it has been a while since i last drove it but it used to be fine, and im fairly sure in D it would change up around 30 odd mph, then again in the late 40 mph range ( i may be wrong,been a while, but thats how i vaguely remember it).
The long and short as it stands is - from a standing start, select 1 move into 2 is fine, from 2 into D is fine, but when in D it will not change up. I never or rarely used 1 or 2, just always selected D from start to finish. I only went through the 1-2-D option today a couple of times to see if it ' wake up D'. I get to around 43mph,revs at around 2200 - and thats it, seems to be stuck at that. Didnt want to bang the throttle down as that to me is not right.
Any help on this would be appreciated, we certainly did not expect this issue
