Oil gallery plug fitting
Llessur
#1 Post by Llessur »
Any advice?
I'm currently rebuilding my 2500 lump and have all the necessary plugs from Chris Witor - the old ones were removed by the machine shop.
Do they go in dry? With Loctite? With RTV?
Are they supposed to be a tight fit? Do they bottom out, or do I just drive them in a certain depth and leave it at that?
The large one at the end behind the backplate feels quite tight going in - almost like it's cross-threading but Chris Witor's stuff is normally right for the job so maybe this is just how they are? Threads seem clean and in good condition.
1977 2500S - White
Re: Oil gallery plug fitting
#2 Post by Alec »
Hello LLessur,
they are tapered pipe plugs (NPT I think?) and should seal dry. However I would use a modern liquid thread sealer as a belts and braces approach.
I did not follow my own advice and recently had to remove my rebuilt engine (Twice, as I blamed it on the rear oil seal which it wasn't) as the rear gallery plug behind the back plate was leaking.
Llessur
#3 Post by Llessur »
Thanks Alec, very helpful. I'll grab some thread sealer :D
Do they definitively bottom out or do they just need to be done up until tight/flush with the block etc?
1977 2500S - White
#4 Post by Alec »
Hello LLessur,
yes, the tapered thread just jams tight, not to a specific depth, depending on the tolerance of the tapping and the plug. So some liquid seal and screw in tight.
