Strombergs, setting up and all that
Posted: Tue Sep 22, 2015 5:25 pm
I had a spare pair of carbs, so got a good knowledgeable friend of mine to strip them and re-build them with new gaskets etc while I ran the car (1970 2000) on the existing, original carbs, which ran fine but were leaking enormous amounts of oil.
My mechanics here in Germany have now removed the old ones and put the recon ones on the car. After a little fiddling it idles beautifully, but gets all in a tiswas at about 1500rpm (especially on the road). Higher revs are also fine and it sounds great.
What could be causing this problem?
The new carbs are also from a 2000, but a slightly later one with extra vacuum connections on each side that normally go to a T piece and to the rocker cover. My car is the earlier type with a diaphragm thing on top of the inlet manifold, so the mechanics (who are very good, but have no Triumph/British car experience) have simply blocked each vacuum hole thing on the carbs, (the originals don't have one at all). Is that ok like that?
Any suggestions?
Any suggestions?
