Starter Motor
Posted: Wed Apr 22, 2015 2:52 pm
Well, I have had a quick look around, and seem to have gotten myself more confused than when I started!!
Basically, my starter has all but packed in on my Mk1 2000. It is of the inertia type.
Now, when I come to remove it today I discovered that the two nuts/bolts holding it too the bellhousing were loose (as in you could move the starter by nearly an inch by hand). So that was problem 1.
Problem two, once I removed the starter (who on earth designed that top ruddy bolt????????) I found that the rear of the shaft (the square end) had significant play in it. On top of that the brushes need to be replaced.
So, I thought I would simply get a replacement starter, and either hopefully send this one back as part-ex, or I could rebuild it myself when I had more time in hand. Then I looked on Witors website, and noted the cost. Hmmmm.
So basically, I have seen mention of Vitesse/GT6 having same starter. Is there anywhere cheaper for one of these (and more importantly can anyone advise me as to the part number so I know what to search for!!).
Also, there seems to be mixed views on High Torque starters, are they worth it?? And if so, where do I get one from?
Or, am I stuck with rebuilding!!
Phil
Phil
