New Member - Need help on Strombergs
Posted: Tue Jun 10, 2014 4:03 am
Hello everyone -
I have a 67 TR2000 mk1 in the US. Owned this TR for a long time but its been sitting for years. Car last legally drivable on the street back in 1991.
Okay so working at this step by step. I did some of the basics to prep starting the 2000 - oil change, oil filter, drain fuel, new oil filter, new plug wires, and new distributor cap. Cleaned the plugs - Bosch something can't recall but re-gapped them at .025. I also squirted some oil down each of the spark plug holes in the head (used mystery oil). Hand cranked the radiator fan and it felt smooth.
The 2000 has an electric fuel pump that was installed prior to me owning it. It worked fine back 20 years ago and I get hear it priming with the ignition switch in the secondary position. Fuel is pumping through the line and visible in the clear fuel filter that I installed.
The problem - Lovely Strombergs. I ordered these ZS 150CD's about 15 years ago from Cris Witor's company. Now they have been sitting on the car with fuel in the float bowls as I have started this car every couple of years but not for the last three. When I have the car in ignition switch setting two the fuel flows but is now leading on the rear carb through a tube on right side and out the bottom screw on the front carb. I ordered a set of carb kits and will give it a go on replacing the o-rings and other gaskets.
Looking for any recommendations from others on getting a 2000 back on the road and secondly fixing these carbs. Note the reason I decided to order these Strombers from England 15 years ago because I could purchase them less than any local shop was quoting to rebuild and tune.
Thanks in advance. I'm going to have some questions on the brake and clutch master soon but will come to that subject after I get the 2000 running.
