Wanted MK1 Heater Parts
Posted: Tue Apr 03, 2012 7:45 pm
by andyborris
My MK1 heater is missing a couple of the operating levers on each side, anyone got some spare?
I know it's a bit of a long shot, but just in case, it's for a very late MK1, there does seem to be differences between early and late MK1 heaters!
Andy
Re: Wanted MK1 Heater Parts
Posted: Tue Apr 03, 2012 7:46 pm
by miles
are they diffrent to mk2 ?
Posted: Tue Apr 03, 2012 10:19 pm
by CAR
miles wrote:are they diffrent to mk2 ?
Yep, mk1 heater unit is under the bonnet, mk2 is behind/under the dashboard.
Posted: Wed Apr 04, 2012 10:54 am
by Clifford Pope
I've a heater (leaking) from a 1964. If you can describe the bit you want you are welcome to it, if it fits.
Cliff
Posted: Wed Apr 04, 2012 6:40 pm
by andyborris
Cliff, thanks, that'll be great!
Early and late MK1 heaters are (I believe) slightly different, but I think these 2 parts are are interchangeable, unless anyone knows different?!
Posted: Mon Apr 16, 2012 3:27 pm
by Clifford Pope
Sorry Andy, I've only just read your reply. I'll dig the bits out tonight.
Posted: Mon Apr 16, 2012 3:46 pm
by andyborris
Thanks Cliff. Reckon I've got till September to get the heater working, so no rush!
Andy
Posted: Mon Apr 16, 2012 6:30 pm
by Clifford Pope
Right, I've removed the bits. They are exactly as in your diagram, which I see is as pictured by Haynes, "Heater control adjustment". They are almost the mirror image of each other - a lever with a cam section on the end for operating a flap.
Both my 64 and 67 heaters have this arrangement, but they are not the same as Haynes "Heater components parts (early type)".
From which it seems that "early" applied only to 1963 and pre-October 1964 cars.
However Haynes "later type" is neither of these - perhaps it means mark 2, which is completely different.
Anyway, if you PM your address I'll be happy to post them off.
Cliff
Posted: Tue Apr 24, 2012 1:58 pm
by Clifford Pope
Hello Andy, just checking you received them
Cliff
Posted: Thu Apr 26, 2012 5:42 pm
by andyborris
Thanks Cliff, not yet is the answer.
Andy
