carpets
I wanted to ask that very question myself.<br>
a) does the commonly advertised set fit Mark 1 as well? (Rimmers, plus several others in SixAppeal)<br>
<br>
b) Does the full carpet set normally include the separate bit that is
glued along the inner sill, and also the bits on the outer sides of the
footwells?<br>
Or does carpet just mean the bit on the floor plus transmission tunnel?<br>
<br>
footwells?<br>
sahtuning2000
- Andy Thompson
- David Withers
sahtuning2000
- Andy Thompson
It\'s very sad but the almost complete unity on the subject of Rimmers quality control is not really a surprise.
I\'m sure we all have our gripes with many suppliers but the Rimmers sub standard theme seems constant... it\'s not as if they are cheap!!!
Amusingly.. almost... a few years ago I turned up there in my brothers Stag.. I really was just passing.. and needed a electric window switch.. I called in and bought one and asked the obvious ... will it fit? They assured me it would.. so I went outside and tried to fit it... obviously it wouldn\'t fit and when I went back inside and complained there was a look of almost horror that I had actually turned up in a Triumph (it was snowing as it does in Lincolnshire)... They apologised and spent a good half hour filing the switch and lubing it with WD40 until I had a still poor fitting but operable switch... it was very sticky though..<IMG>
Another classic Rimmers moment was ordering a recon rack for my younger brothers Dolly 1500HL (MOT failure).. a new rack promptly arrived... for a TR7!!! This was the correct rack they insisted..it came from the right stock bin... I could go on but for the most part I have stopped using Rimmers <IMG>
