Barn Find Triumph Pi
Tinsmith_Skippy
Re: Barn Find Triumph Pi
New update been a while. I've have been busy I have checked over the engine and serviced where necessary. it's s quite a low mileage car but I have checked the bores and bearings all looked good so new gaskets and ancillaries fitted, new core plugs in the exhaust side and lick of paint. I've made an engine stand for storing it while other things are going on.
Last edited by Tinsmith_Skippy on Thu Jul 13, 2017 9:01 pm, edited 1 time in total.
Tinsmith_Skippy
After all the effort the car is finally for the first time in Valencia Blue! Now the to do list has now quadrupled.
Last edited by Tinsmith_Skippy on Thu Jul 13, 2017 9:00 pm, edited 1 time in total.
WOW!
That is stunning!! Top work! Keep it up, keep showing us please!
best restoration ive ever seen on our cars amazing attention to detail all credit to you cant wait to see car finished,
Fantastic!
- triumphman
I'm amazed at the attention to detail. It's really good to see that you're doing such a fantastic job. I hope I'll be able to see the car 'in the flesh' in the future. Keep up the good work, and keep posting!
Andy Roberts
Hon. President
1974 Del Lines Stag Estate Black and Blue VML 3M (was TNH 10, then JJH 818N)
1975 Del Lines Stag Saloon Mimosa JNY 590N "Janey"
1974 Triumph 2000 Saloon Pimento SAD 971N "Sadie"
Blog: Andy's Triumph Stuff
Hon. President
Tinsmith_Skippy
Hello everyone I have a small update on the PI, just been sorting out boxes of fixings and parts which I have labelled thankfully and I have made a start. The brake lines and fuel lines have been fitted along with the sound proofing on the bulkhead on the inside, this being upgraded to a thicker modern neoprene material along with all the floor mats. The engine bay sound proofing I have decided to leave off really due to the deterioration of the material. When I removed this material there was rot in the bulkhead which has been repaired but suggests the sponge holds water from the outlets to the heater intake. The wiring loom is in place and will probably need shifting around a little. The lights and grille are installed.
I really appreciate the interest in the project really helps to keep the momentum going.
Last edited by Tinsmith_Skippy on Fri Jul 14, 2017 4:14 pm, edited 1 time in total.
Excellent, inspiring work!
Seeng the gearbox cover plate, did you fit new cage nuts? My PI's were rusted solid and I had to drill them out...
Tinsmith_Skippy
Hello Jim, I did manage to remove the cage nuts successfully. They were smothered in the factory bitumen coating which probably saved them to an extent. I have had a lot of the unique fixings and other bits yellow passivated which took a
long time at the Platers. I think it was 8 weeks! I didn't even enquire about the time to chrome bits. In the time the platers had mine and my Dad's Pi bits and bobs I bought a plating kit on eBay. Plated bits so far: window wiper bracket and mechanism cover and the cage nuts for the gearbox surround and radiator. The clear passivate I've had good results with, the yellow however is bit hit and miss and experimenting is still in progress. I'll post some more pics after the next plating session.
Last edited by Tinsmith_Skippy on Fri Jul 14, 2017 4:35 pm, edited 5 times in total.
