carpets
kingston
#1 Post by kingston »
does anybody have any blue carpet set(s)for a mk1,or does mk2 sets fit? if i have to buy new does anyone know of agood supplier
#2 Post by Clifford Pope »
I wanted to ask that very question myself.<br>
a) does the commonly advertised set fit Mark 1 as well? (Rimmers, plus several others in SixAppeal)<br>
<br>
b) Does the full carpet set normally include the separate bit that is
glued along the inner sill, and also the bits on the outer sides of the
footwells?<br>
Or does carpet just mean the bit on the floor plus transmission tunnel?<br>
Poole_A
#3 Post by Poole_A »
I have temporarily fitted a MK2 carpet set into a MK1. Only difference I noticed was around the dip switch.
sahtuning2000
#4 Post by sahtuning2000 »
also most times if you get a mk2 set the seatbelt buckles are on the tunnel,most mk1s are on the rear footwell
Andy Thompson
#5 Post by Andy Thompson »
Rimmers Mk1 carpets are rubbish... Jimmy Elliott fitted a \"free\" set to his Mk1 ... not very impressive I\'m afraid
#6 Post by Clifford Pope »
So who is a good supplier? And what is included?
Brian
#7 Post by Brian »
Hello all
I too found Rimmers carpets to be rubbish when I put them in my MK2.
Very thin and chunks of material soon came off
David Withers
#8 Post by David Withers »
As well as the useless stainless steel exhaust that I recently wrote about, I also bought a carpet set from Rimmers for my Mk II in 1998.&nbsp; I think \'rubbish\' is too kind a description!
sahtuning2000
#9 Post by sahtuning2000 »
so rimmers carpets are rubbish!!i can tell you that the chap i bought my 64 mk1 from,got a stainless exhaust from rimmers,he had a nightmare with the fit,also its well loud,he found that annoying aswell!!
Andy Thompson
#10 Post by Andy Thompson »
It\'s very sad but the almost complete unity on the subject of Rimmers quality control is not really a surprise.
I\'m sure we all have our gripes with many suppliers but the Rimmers sub standard theme seems constant... it\'s not as if they are cheap!!!
Amusingly.. almost... a few years ago I turned up there in my brothers Stag.. I really was just passing.. and needed a electric window switch.. I called in and bought one and asked the obvious ... will it fit? They assured me it would.. so I went outside and tried to fit it... obviously it wouldn\'t fit and when I went back inside and complained there was a look of almost horror that I had actually turned up in a Triumph (it was snowing as it does in Lincolnshire)... They apologised and spent a good half hour filing the switch and lubing it with WD40 until I had a still poor fitting but operable switch... it was very sticky though..<IMG>
Another classic Rimmers moment was ordering a recon rack for my younger &nbsp;brothers Dolly 1500HL (MOT failure).. a new rack promptly arrived... for a TR7!!!&nbsp; This was the correct rack they insisted..it came from the right stock bin... I could go on but for the most part I have stopped using Rimmers&nbsp; <IMG>
&nbsp;
&nbsp;
