EBay - 2500S For Sale
Enter any items seen or placed in other ads, either Ebay, Auto Trader, Local Press, etc.
1. If Ebay, Please state Ebay reference number and/or provide a link. 2. If other, i.e. Auto Trader or Local Press, state date/issue published and location. 3. Please stick to relevant links, i.e. Triumph 2000 related only.
johnfrancis898
#1 Post by johnfrancis898 »
Anyone know anything about this car? MWB 941P. Is it known to anyone? Looks good on the photos. My mate is interested but not at that price.
Member no. 7941.
Re: EBay - 2500S For Sale
#2 Post by johnnydog »
Hi John,
I dont know the car, but on first impressions, the following jump out to me....
- some gremlins under the vinyl panel on the nearside C pillar
- no sill trims (an indication of previous sill work?)
- no chrome trim on the windscreen rubber
- on the nearside especially, there looks to be a lot of previous panel repair work (the saying more filler than in the Isopon factory comes to mind!) The f/n/s door is out of alignment, and the r/n/s door bottom is proud
- obvious repair work to the lower front valance on the offside
- the profile of the front nearside wheel arch is wrong
- wrong radiator
- boot trim looks tatty
- not sure why it has a PI vacuum tank..?? I assume the hose over the rocker cover (which isn't correct) feeds it?
- the lower front wing badges are in the wrong place (the fresh paintwork a probable reason!)
- mileage stated as 32k - I'd take that with a pinch of salt, especially as it has the wrong speedo fitted (should be a 140mph speedo - 120mph speedos were in the 2000 models!)
Personally, I wouldn't touch it with a barge pole. I know your friend has been looking for a good while now John, but I'd be looking elsewhere....
johnfrancis898
#3 Post by johnfrancis898 »
Thanks Johnnydog, I had spotted most of those. Strange about the Pi expansion tank! I think we will pass on this one.
Member no. 7941.
#4 Post by johnnydog »
Just noticied too - it's got the earlier fuel, amp and temp gauges - the needle on facelift cars should swing from the bottom!
Plus the choke knob is wrong...
I think you are wise to give it a miss!
