Sill progress
Sill progress
#1 Post by simon.williams » Sat Apr 26, 2025 5:52 pm
Inner sill repairs now done! 4 plates welded on. Middle sill to go on next.
Re: Sill progress
#2 Post by simon.williams » Sun Apr 27, 2025 2:59 pm
Plus welding in the nice new jacking points.
Re: Sill progress
#3 Post by johnnydog » Sun Apr 27, 2025 9:08 pm
Looking very good! :wink:
Re: Sill progress
#4 Post by Charles H » Mon Apr 28, 2025 8:00 am
Lovely.
Re: Sill progress
#5 Post by simon.williams » Mon May 12, 2025 8:57 pm
Middle sill now welded in place, ground down & seam sealed.
Outer sill next.
Re: Sill progress
#6 Post by simon.williams » Wed May 14, 2025 6:24 am
Outer sill trimmed to fit and button weld holes drilled.
Re: Sill progress
#7 Post by simon.williams » Sat May 17, 2025 5:01 pm
Outer sill now welded on. Getting closer!
Re: Sill progress
#8 Post by simon.williams » Sun May 25, 2025 4:25 pm
Getting there slowly but surely!
The only part I’m a bit dubious about is the c-post where I have had to do quite a bit of patching and welding. Hopefully got all the rot out. At least I know the metal is good below it!
Re: Sill progress
#9 Post by johnnydog » Sun May 25, 2025 8:46 pm
Looks like you've been busy!
Don't forget to create the artificial seam at the back of the sill where it meets the front edge of the rear wing! All too often this seam is lost during repairs and it just doesn't look right without it and is an obvious indication that repairs have been carried out!
Well done with all the effort you've put into it so far though!
Re: Sill progress
#10 Post by simon.williams » Mon May 26, 2025 8:34 pm
Thanks, I’ll look into where this seam should be and see how I can do one.
Front wing patch went on this evening, much head scratching and trimming, but now fits well.
