I have a knocking noise on the off side front suspension.
I have fitted a new wheel bearing kit but there is still play and faint knocking noise when rocking the wheel side to side. No play top to bottom.
I think it could be the stub axle, anyone got any ideas?
Many thanks
Paul
Knocking noise front suspension
- herald1360
Paul Barlow
Exeter
1974 2500TC French blue
Exeter
Re: Knocking noise front suspension
Hello Paul,
worn stub axles would usually be evident when fitting new bearings, both visibly and by a slack fit of the inner bearing on the shaft.
There should be some slight play in the front wheel bearings, do not try and completely eliminate the play.
Also have alook at the rubber supension bushes in case that is the source of the noise?
Also Ball Joint, Tie Rod or sleeve bearing in the suspension top mount (though more noticeable when manoeuvring during parking).Alec wrote: ↑Sun Mar 16, 2025 8:36 amHello Paul,
Also have a look at the rubber suspension bushes in case that is the source of the noise?
