cut-outs after reving above 4500rpm
iani
Re: cut-outs after reving above 4500rpm
#21 Post by iani » Tue Apr 02, 2024 11:44 am
Do you have a fuel pressure gauge? It would be useful to see if the pressure is dropping at higher RPM, that would suggest either too narrow a fuel pipe or, more likely, a tired pump.
GinettaG15
#22 Post by GinettaG15 » Tue Apr 02, 2024 10:17 pm
as said above: the problem is present with mechanical pump and with electric pump..so it cannot be the pump. the fuel-pipes are the usual ones...nothing too narrow...those pipes could feed a 8L v8 engine
