M2 PI PFL - Fog light wiring
iani
#1 Post by iani »
The PFL PI has a yellow/red wire in the loom for front foglights, can anyone tell me where this terminates behind the grille as standard? On my car it is under the slam panel, in the middle, I'm not sure if that is standard however as it ends in a choc block connector, what would have been standard?
Ian
Re: M2 PI PFL - Fog light wiring
#2 Post by Charles H »
That is the standard position, however it would originally been a male bullet connection on the wire with a single female end pushed on to it.
#3 Post by Dave B »
Charles H wrote: Mon Oct 31, 2022 9:01 am That is the standard position, however it would originally been a male bullet connection on the wire with a single female end pushed on to it.
Exactly how Charles describes. I've done a few over the years and they were all like that.
Don't forget, only Lucas Square 8's look right! :D
iani
#4 Post by iani »
Thanks Charles, I thought as much.
iani
#5 Post by iani »
Dave B wrote: Mon Oct 31, 2022 9:34 am
That's what I'm fitting, I used to have them on a Stag and they've been taking up shelf space.
