Clutch master wanted
Sloppy 2000
#1 Post by Sloppy 2000 »
Hi.
I have hit a bit of a problem. I think my car came to me with the wrong clutch master. I replaced the servo exactly for what I had on there. But has to remove clutch master. When I did I noticed it was a bit crushed. Well it's been on there ever since I got it about 5 years ago. Anyway it worked. Put it back on. Worked fine. Then I found a drip 😕. According to the chassis number. It ought to have later one on. Jonny fog thinks it probably should be. The reservior is further away from the bulkhead and fits past the bigger servo on the later MK1. Mine is a 68.
It's kept me off the road a while. CW doesn't have one. Is there anyone out there that could help?
Triumph 2.5PI Valencia
david_lall
Re: Clutch master wanted
#2 Post by david_lall »
Have you tried Andy Harrison - he's often a great person to ask for second hand parts. Pm me if you need a number
David Lall
1978 Carlight Casetta Caravan
#3 Post by johnnydog »
Maybe I should have posted the fact, but I have managed to help Jeff out with a used late Mk1 / Mk2 master cylinder, resevoir and bracket.
