Hello there,
If any one knows of a good set for sale that are not silly money please do let me know
Sal
Twin SU HS6 Wanted
Re: Twin SU HS6 Wanted
I may have a used pair of HS6's, but will have to check and get back to you. Do you want just the carbs, or the inlet manifold as well?
Hi Johnny, sorry for the delay
I have a manifold for my HS4’s so I guess that’s the same so if it is then just the carbs will do
I will PM you as well
Sal
Sal
Hi Sal,
I thought SU HS4s were only a two stud fitting to the inlet manifold, whereas HS6s were a four stud fitting?
Maybe you could just check to confirm, but I will have the 4 stud inlet manifold if needed with the HS6s which would be a straight swap.
Yes you’re right my HS4’s are 2 stud fitting so I’ll need the manifold as well and if they are complete with linkage even better
Sal
Sal
Sent you a pm Sal
