mk1 steel wheel
Re: mk1 steel wheel
Mk1 rims are very narrow at I think 4.5J. Mk2 steel rims are wider and are either 5J . This from memory and someone else will be able to confirm the exact dims. I have a set of Mk2 rims which still take the Mk1 hub caps and embellishers which are free for you to collect if you want them. Bonus is that I am near Folkestone, Kent. Depends on how original you want to go. I find the stabilty of a Mk1 is far better with the Mk2 wheels!
Re: mk1 steel wheel
@jonnydog - that excellent! many thanks. That's just what I need - my lower dash trim panel search begins. Had a quick look under the dash to see lots of cut wires and dangly bits (including several empty bulb holders just hanging loose), so scope to tidy up the wiring and hopefully prevent any issues in the future.
@charles H - yes please re wheels! Its more the original 'look' I'm after - my cars been hacked around too much over the years to go for the 'rolled off the production line' angle but I can try to get back to what it used to look like (by changing wheels and dash for example!). I'm in Ashford once a week. Happy to fit around you for collection.
Toby Crayden
Register member 7985
Gravesend, Kent
1965 Mk1 Triumph 2000
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Re: mk1 steel wheel
PM sent
Re: mk1 steel wheel
I'm not promising, but I know I have various upper and lower Mk1 dash trim sections, although I would have to check whether I have any early lower sections. I can let you know by the weekend if you can't locate one elsewhere....
As you probably are aware, the Mk1 dash trim is bolted and glued to the metal dash structure, and it is quite time consuming to remove it without damage, but is quite doable with care. The dash on a Mk2 comes out as one unit, whereas the Mk1 is basically a trim covering over the fixed metalwork forming the dash.
Re: mk1 steel wheel
if want to sell TR6 wheels let me knowTobyC wrote: ↑Sun Feb 14, 2021 5:47 pmThanks. I'm in no rush - currently she sits on TR6 wheel as per photo so very usable 'as is', I'd just like to get her back on original wheels at some point!
Good question re dash. Its a pre facelift Mk1 (built 1964, registered in 1965) and dash currently looks like the photo so I assume I need the whole lower section which includes around the steering wheel. I'd also like a pre face lift steering wheel but I suspect they are quite rare now and I can see people on facebook have all sorts of hassle with steering wheels so my plan is to sort the dash and then do the steering wheel later. Looks like someone must have blanked off the vents (?) and cut out the section to add the gauges. I haven't taken the panel off yet to see what lurks behind but hopefully the vents can be reconnected and wiring tidied up when I have the dash off.
1964 MK1 2000 SaloonConiferMOD
1964 MK1 Cactus over Conifer
1966 Mk1 estate
1968 MK1 PI In Jasmine
1995 Rover 820 Vitesse Turbo
x3 1962 Triumph Tina scooters
1966 Mk1 estate
Re: mk1 steel wheel
Many thanks. Search online has drawn a blank so far so I would be interested in knowing if you had one / how much. Previous owner has also fitted extra warning lights above the indicator lights which might account for the 'spare' bulb holders stuffed up behind the dashboard (which I suspect are the original bulb holders for all my warning lights) and the fact I've never seen a warning light come on except the red ignition light... why someone thought it easier to drill and fit extra warning lights rather than fix the ones in the dash I suspect I'll never know! I'll get a photo - it must have been a 'dash out' fix that took some planning!johnnydog » Mon Feb 15, 2021 11:34 pm
Toby Crayden
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Re: mk1 steel wheel
Will do. Once wheels swapped over, my TR6 versions become surplus to requirements.englishbull » Tue Feb 16, 2021 9:35 am
Toby Crayden
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
Gravesend, Kent
1969 MG C Roadster
2018 Mini Cooper
2020 Range Rover
