Mk1 windscreen washer tube routing?
tony.rayns
#1 Post by tony.rayns » Tue Nov 24, 2020 1:01 pm
Bonjour!
I need some help from my fellow Triumph enthusiasts please..........
My Mk1 PI restoration has been ongoing for almost 30 years and it's 99% there. However one job I've been putting off is the tube connections from the washer bottle/pump to the jets on the scuttle? Old age plays tricks on my memory and I just cannot remember how or where this tube threads through the bulkhead to the underside of the scuttle?
I've looked in the parts and workshop manuals to get an idea but no joy there so any advice or recommendations would be welcome.
Thanks in advance.....
Tony
Tony
Member No 4250
Current moneypit is Mk1 PI Valencia Blue AMX 10H
Re: Mk1 windscreen washer tube routing?
#2 Post by Clifford Pope » Tue Nov 24, 2020 3:24 pm
Assuming the bottle is mounted on the bulkhead about 1/3 of the way along from the nearside wing, the pipe runs back underneath the ledge and comes through into the chamber over the heater, a distance of about 4". Remove the scuttle vent cover for access to the T-junction.
https://car-from-uk.com/sale.php?id=10635 - picture number 7 shows the pipe under the scuttle vent panel.
#3 Post by johnnydog » Wed Nov 25, 2020 12:40 am
Interesting photos - unrelated to the question, but that is Bob Maddocks old PI, which he sold a good number of years ago. Had a serious corrosion issue on the bulkhead and inner front wings apparantly....
tony.rayns
#4 Post by tony.rayns » Wed Nov 25, 2020 1:55 pm
Thanks for your response Clifford :) (and there's a big but coming here), BUT, I've looked all around the heater box aperture :roll: and can find no access hole for said washer tube, I have even removed the bonnet latch just in case there is something lurking behind it but another blank.
With the scuttle removed I can feel all around with my fingers - all to no avail.
The only hole I can find is the one shown in the photo that accesses the cabin behind the glove box. If the tube goes through here into the cabin how does it route through to the scuttle area? I'm pulling my hair out here - something that I'm sure is so simple but I'm just not getting it!
Any further advice will be greatly received!
Time for a cuppa I think...........
PS. Jonnydog, do you suffer from insomnia? :roll:
Tony
Member No 4250
#5 Post by Clifford Pope » Wed Nov 25, 2020 2:41 pm
I don't know. If the washer bottle fits in the position of the one in the picture, as mine does, then the vertical hole into the scuttle chamber under the grill would be the nearest and most obvious route. Drill one?
tony.rayns
#6 Post by tony.rayns » Wed Nov 25, 2020 3:37 pm
That's my plan B. If there is no further advice overnight then it's going to get "the treatment" tomorrow afternoon! Shouldn't need to drill it tho, there has to be one already there but just can't find the illusive bugger :evil:
Many thanks Clifford........
Tony
Member No 4250
#7 Post by Charles H » Wed Nov 25, 2020 4:13 pm
My Mk1 not here at the moment, but I am pretty sure there is a hole with a grommet that it goes through. May have other wiring or cable going through it too.
#8 Post by Clifford Pope » Wed Nov 25, 2020 4:41 pm
Here are the coordinates - I've just been out to locate it.
The hole is 1" back from the front edge of the tray, and 2" away from the nearside edge.
Mine doesn't have a grommet - the plastic tube is a loosish interference fit in the hole.
tony.rayns
#9 Post by tony.rayns » Thu Nov 26, 2020 3:57 pm
Charles,
Yeh...... could find a couple of grommets that take you into the cabin but nothing up to the windscreen scuttle.
Clifford,
Many thanks for the co-ordinates - job done this afternoon ta :D
Tony
Member No 4250
