Mk1 Pi Restoration
Amazing and impressive work again Ross!! Well done!!
Re: Mk1 Pi Restoration
Fantastic and impressive work again, just stunning Ross!
Hello John & Dave thanks for the comments. The spraying is moving along just when you think the light is at the end of the tunnel some extra parts that needed painting that I didn't think off have been added to the list.
Door Straps & Fixings
Front doors in top coat, now wet sanded, buffed and ready to fit.
Rear doors have been sanded 320g ready for next coat of white primer for blocking.
No spray booth oven needed yesterday afternoon, 36 DEG outside. Toastie!
Couple more weeks and should be done.
That's coming along very nicely Ross.
It took a little longer than expected but there is white at the end of the tunnel. The boss is pleased anyway.
Just got to put it back together now!
If you find you haven't time to finish it Ross, I'll take it off your hands
Splendid work Ross as usual!
Gorgeous Ross! Surely turned out better than it would have done had it been to the bodyshop...
Can you forward me a couple of higher res images pretty please?
(Andrew, sixappeal@triumph2000register.co.uk)
Fantastic work Ross!
