Hello from Australia
New to the forum? Just joined the Register? Introduce yourself here.
claude626
#1 Post by claude626 »
I am the proud new owner of a AMI built Topaz2000 Mk2.
It has had a transplanted 2500 engine, with a serial number of MM46649HE. Is this a TC or S engine?
CAR
Re: Hello from Australia
#2 Post by CAR »
The TC and S had the same engine from May75, so all S models have an MM engine number.
The give away is the long inlet manifold and SU HS6 carbs on the TC/S engine. Earlier TC engines had HS4 carbs and shorter manifold.
