Triumph Pi Barn Find
Tinsmith_Skippy
#1 Post by Tinsmith_Skippy »
There was some issues with using photobucket, so I’ve created this thread so I can sort out the original thread having no photographs.
Busy couple of days with the aircraft stripper and hot air gun.
Last edited by Tinsmith_Skippy on Fri Jul 13, 2018 5:27 pm, edited 24 times in total.
Tinsmith_Skippy
Re: PI Project
#2 Post by Tinsmith_Skippy »
Last edited by Tinsmith_Skippy on Fri Jul 13, 2018 12:35 pm, edited 15 times in total.
Tinsmith_Skippy
Re: PI Project
#3 Post by Tinsmith_Skippy »
Hello all another update bought some epoxy mastic and painted the underside and now masked the seams for the seam seal application.
Last edited by Tinsmith_Skippy on Fri Jul 13, 2018 12:44 pm, edited 11 times in total.
Re: PI Project
#4 Post by Dave B »
Very impressed with the standard of your work and meticulous attention to detail. Cant wait to see the finished article!
Tinsmith_Skippy
Re: PI Project
#5 Post by Tinsmith_Skippy »
Last edited by Tinsmith_Skippy on Fri Jul 13, 2018 12:44 pm, edited 8 times in total.
Re: PI Project
#6 Post by Dave B »
I'm pretty sure that once you've done all the 'ugly' bits, you'll pay just as much attention to the 'shiny' bits.
Tinsmith_Skippy
Re: PI Project
#7 Post by Tinsmith_Skippy »
All new applied seam sealer inside the car and the boot area with epoxy coat over the top.
Next job have some rubberised stone guard stuff to put on, a small mile stone the car can come off the
Last edited by Tinsmith_Skippy on Fri Jul 13, 2018 12:50 pm, edited 4 times in total.
laurence
Re: PI Project
#8 Post by laurence »
Excellent work, thankyou for sharing, always good to see a 'no corners cut' restoration, well worth it in the end,
cheers,
Laurence
Tinsmith_Skippy
Re: PI Project
#9 Post by Tinsmith_Skippy »
Wings in position with self tappers. Alignment of bonnet needs attention, may have to try another bonnet before I start playing around with the brackets. The near side corner of the bonnet is riding up slightly where it meets the front panel.
Last edited by Tinsmith_Skippy on Fri Jul 13, 2018 12:42 pm, edited 6 times in total.
Re: PI Project
#10 Post by Charles H »
Looking great Ross.
The proud bonnet at the hinge is common. It is due to the hinge becoming stiff and the hinge itself bending slightly. The cure is a little brutal, but a blanket on the bonnet, a large flat piece of wood and a very heavy hammer sorts it, Oh and a large dose of the brave pills!
Keep up the posts, love it!
