I'm looking for a small Smiths rev counter — I know they exist because I've seen one before.
Anyone happen to have one?
James
WANTED: Smiths Rev Counter — 2 inch
1969 2000 MkI EFI
1969 Spitfire MkIII
1969 Spitfire MkIII
- david_lall
Re: WANTED: Smiths Rev Counter — 2 inch
I think this is about the smallest you can get - don't know where you'll buy an original one though, this one came from an auto jumble. Might be worth trying Demon Tweaks, Holden or Europa Car Spares for new versions.
David Lall
1978 Carlight Casetta Caravan
Not Smlths............... but 2"/50mm...........not cheap either !
http://www.ebay.co.uk/itm/VDO-Vision-Ra ... 5d37db6258
- TedTaylor
Like David I am sure Smiths never did one this small ....... however I did have a small one of some make or other many many years ago in my spare 'instruments box'. Just keep your fingers crossed that it is still there ........ and that it will work!
Ted
Ted
I've seen a Smiths one before for sure — so I know they exist.
I have seen you can get other makes — I just fancy a Smiths so it looks right.
The other option is a Mini sized one — not sure I've seen a 6 pot one though.
1969 2000 MkI EFI
1969 Spitfire MkIII
1969 Spitfire MkIII
Not sure if this a small Smith's one (looks it and diagram called impulse)) but unfortunately they don't sell em
http://www.speedograph-richfield.com/ht ... meter.html
Also not sure if you ben on here may help
http://mk1-performance-conversions.co.u ... trical.htm
Found this one on demon tweeks web site for £54.53. Not smiths but only 52mm.
http://www.demon-tweeks.co.uk/performan ... tachometer
- TedTaylor
These are all the standard size ones - got quite a few 7k and 8k ones ..... and even a 10K one ..... in the box.englishbull wrote:Not sure if this a small Smith's one (looks it and diagram called impulse)) but unfortunately they don't sell em
Ted
