Wheels on the 4x4 Estate
iwontone
Re: Wheels on the 4x4 Estate
#11 Post by iwontone »
when you get or have your tyres fitted to alloys,,,do you ask for tyre sealer(black sticky stuff) or just soap,,,mine did the same losing air until sticky stuff was stuck on,,i still check tyre pressure`s about once a week,,,may worth a try
mikew
#12 Post by mikew »
iwontone wrote:when you get or have your tyres fitted to alloys,,,do you ask for tyre sealer(black sticky stuff) or just soap,,,mine did the same losing air until sticky stuff was stuck on,,i still check tyre pressure`s about once a week,,,may worth a try
the first time soap, next removed tyres cleaned rims and alloy, painted allow with hammerite, had sticky stuff applied - still leak !!
FF Stag V8 Estate White
TR5 Valencia Blue
Stag Red
Jensen Interceptor MK1 Ice Blue
The Blog to be found at http://standardtriumphcars.blogspot.com/
radders
#13 Post by radders »
Mike,
You're definitely right not to do the RBRR on tubed tyres. I did the CT 10 countries run on tubed tyres and ended up having two puntures and had to borrow two wheels to get home.
Todays tyres are mostly ribbed on the inner side walls and this will just chafe through the inner tube.
Plus, no-one will care about what wheels you have on, everyone will just be pleased to see the car taking part in such a huge challenge after such a mammoth restoration! :D
1969 Mk1 2.5 Pi in White
1967 Mk1 2600 in Wedgewood (Gertie2)
http://kingratracing.blogspot.com/
Steve Knight
#14 Post by Steve Knight »
Take the tires off and sand the inner rims with a flexible rubber disc - stick on 80 grit is best. This must end up perfectly clean. Hammerite is no good for aluminum, it just flakes off. You must then paint using a special primer. Even rubbing down the first coat can help with a good seal. It is very unlikely your rims are porous. Clean the edges of the tires with petrol, any bits missing here will lead to leaks. Hardly any modern tires are designed to run inner tubes; they have a rough inner carcass which will rub a hole in tubes. Inner tubes a not even made for low profile tires.
Steve Knight
mikew
#15 Post by mikew »
Thank you both for your advice, I knew there was a good reason not to use inner tubes.
I do want to keep the car original and 15" minilites with 185s have a very similar rolling radius to 14" with 175s according to Mintylamb, so there's no real gearing gain there - in fact with the wrong tyres 15" can reduce the rolling radius !
So I am simply going to sort out the S alloys - its only a little job
mike
TR5 Valencia Blue
Stag Red
david_lall
#16 Post by david_lall »
Until I gave up on keeping wire wheels looking pristine I ran with inner tubes for many thousands of miles with no trouble at all. The tyre fitters actually insisted on the inner tubes!
David Lall
1978 Carlight Casetta Caravan
mikew
#17 Post by mikew »
The decision is made, I am sticking with S alloys, and buying the new set that Lee has. This helps us both, the car stays original too.
I would use Minilites on a racer / fast road car because of the better rubber available and more low profiles, but there is no real gearing advantage, and it won't recreate the original 70s 4x4 driving experience - which has been a part of this exercise anyway
TR5 Valencia Blue
Stag Red
owen1183
#18 Post by owen1183 »
my 's' alloys loose all air within a week..... all 4 flat as a pancake...... right pain the the ass.
Im thinking of getting new wheels so I dont have to keep pumping the damn things up
#19 Post by Alec »
Hello Owen,
it would be a lot cheaper to do as Steve suggests and clean up the inside of the wheels where the tyres seat. All the aluminium wheels I've seen that leak are due to the breakdown of the paint finish internally so the tyre bead can't seal.
#20 Post by Mike Stevens »
I've got home-refurbished 'S' alloys on the PI and they've been fine for the 18 months they've been on there. I've also a got recon/exchange set on the Stag which has also not lost any air - but only in the last 5 weeks!
I agree about the bead seal. Any alloy corrosion there seems to easily leak air.
