Scrap gearbox
Steve Knight
Scrap gearbox
WANTED. I need a gearbox rear adapter plate / to A type o/d. After a successful dummy run ( aligning up the second, rearmost set of splines - no springs ) then trying several times to bolt the thing together, I decided it needed a bit more force ! and broke the adapter plate. The correct method would have been to remove it ( again ) and make sure the pump didn't snag on the oval cam. My late A type has 8 return springs ( hence dimples ). Did other overdrives only have 4 ?
Steve Knight
- Andy Thompson
Re: Scrap gearbox
2.5PI Stag and TR is eight spring unit
I believe some Stag A Types were 25% but don't quote me
Perth WA
1970 2500PI estate
1964 2.7PI saloon
1973 2100 EFI Megasquirt
1972 Stag
Very Big garage
1970 2500PI estate
1964 2.7PI saloon
1972 Stag
Very Big garage
