Jonathan Lewis wrote:if the Holden engine is deeper than the Triumph unit, has someone put spacers between the front suspension crossmember and the chassis rails in order to give sump clearance without fouling the bonnet above? ... could this perhaps be raising the front ride height (which does look high) and leading to a positive camber condition?
Fair point, Alec - the compressed length of the struts would effectively determine the ride height, so packing between the crossmember and chassis rails would effectively just lower the crossmemberAlec wrote:that, surely, will not affect the ride height just alter the angle of the track control arm relative to the base of the strut (which will alter the camber also?) and probably result in the track control arm contacting the bump stop?
As Colin has pointed out, the issue may just be sagging rear springs unbalancing the whole. FWIW, I've just applied the Monarch method of ride height measurement to the rear arches of mine (PFL standard ride height on CW 395lb/in springs) and the resulting dimension from wheel centre to arch lip is a tad short of 12".
