Quick question - the trailing arm hub mounting studs (6 on each trailing arm that secure the brake backing plate/ bearing carrier), are they just tapped straight into the alloy (with no thread insert)?
I've got one on each side's trailing arm which won't tension properly- they both appear to be pulling out? The repair will be fairly simple once I purchase a 5/16 UNF thread repair kit.
Rear trailing arm hub mount bolts
David
Re: Rear trailing arm hub mount bolts
Yep! Straight into the alloy! The torque setting is pretty low for these about 12lb/ft if my memory serves me correctly. The fix is to fit a helicoil or similar.
Interesting design
, I guess I'll be doing some helicoils in the near future. Thanks.
David
I learned about this the hard way in my late teens, over tightening not one, but three. Discovered one of them had come out and was happily sliding around inside the brake drum for long enough to wear an angle in the end!
In the end I had stepped studs made up, with oversize UNC (coarse) threads at one end, with the training arm drilled and tapped to suit. The stepped studs were then fitted very carefully!
Another step towards being an expert learned the hard way!
Regards
Regards
David Brewster (Memb 3937)
Edinburgh
2500S in White, with blue cloth interior. Manual Overdrive
2500S in Rus(se)t Brown with beige cloth interior. Manual Overdrive, but originally auto
Edinburgh
I torqued them to 15Nm and that was enough for two of them to let go- luckily they're holding and have just started to pull out. If I hadn't checked the manual I wouldn't have realised how "loose" they need to be- and probably would have a lot more to do.
David
