Wind noise
Ltriumph
Wind noise
#1 Post by Ltriumph » Thu May 26, 2022 8:40 am
Hi - probably discussed previously but couldn't find a post. Have a lot of wind noise. Appears to be from a gap at the top of both front doors as there are gaps (used a torch). Any ideas how to reduce the noise? Not sure new rubbers would do a lot.
Triumph TC 2000 1978
Triumph Bonneville T120 2018
Re: Wind noise
#2 Post by Alec » Thu May 26, 2022 8:55 am
Hello Ltriumph,
you have correctly identified the cause. If you can slacken the door and readjust it so the gap is eliminated, that is the easiest soultion. If that then gives too bad an alignment problem relative to the body, then the frame will need bending, to suit the aperture. I would suggest, if going that route using ratchet straps and a block of wood to keep the door ajar. Wind the windows right down while doing it.
Phil T
Re: Wind noise
#3 Post by Phil T » Fri Jun 03, 2022 9:28 pm
Check the rubbers first.
I had a similar issue and changing the rubbers cured the wind noise.
