These don’t want to move…
Had to grind the downpipe off. These studs are firmly in place. I will probably end up drilling them out, but any ideas? Heat?
Re: These don’t want to move…
Hello Simon,
I find that heat works most of the time, I am fortunate that I own an oxy\Acetylene set so can get things really hot.
What do you have as a heat source?
A blow torch…not in the same league sadly…
Ha, welded nuts! And I think what helped was some sharp taps from a centerpunch from the other side, certainly seemed to make a difference. And the nuts welded close to the manifold.
Its the little victories!
I would now clean the threads with a tap, (5/16" UNF probably, or maybe 3/8" UNF, I'll have to check) with some engine oil on the tap threads.
Cheers, Mike.
Cheers, Mike.
I'm sure the manifold studs are 3/8" UNC.
https://www.chriswitor.com/proddetail.php?prod=CW3519K
Thanks, new studs & exhaust are on their way from Chris, will look for good taps.
Hello Simon,
not forgetting brass, rather than steel nuts.
Thanks for the tips!
I stand corrected, but at least the idea was good - thanks Dave.Dave B wrote: Mon Jun 30, 2025 11:11 pm I'm sure the manifold studs are 3/8" UNC.
