poppyman
#41 Post by poppyman » Wed Feb 28, 2024 10:07 am
Hi Alec, yes checked with dwell meter all items fitted have been checked and all items replaced for a second time off a good running car. I must be missing something somewhere.....
#42 Post by Alec » Wed Feb 28, 2024 11:55 am
Hello Tony,
did you try another king lead itself?
iani
#43 Post by iani » Wed Feb 28, 2024 12:15 pm
Have you checked the security & condition of the engine earths? Perhaps a clean up & re-securing might be in order.
poppyman
#44 Post by poppyman » Wed Feb 28, 2024 1:00 pm
One new set of leads complete and one set off another running car Alec.
poppyman
#45 Post by poppyman » Wed Feb 28, 2024 1:03 pm
All the earths have been checked and cleaned Ian, even put jump leads on direct to the block as well.
poppyman
#46 Post by poppyman » Sat Mar 02, 2024 3:21 pm
Hi gents, finally found the problem. when go 12volt with an inline ballast, you must remove the wire from the starter and replace it with another direct to the the coil... it then gives a spark when cranking.. Totally stupid idea!!
Bad running was down to weak mixture on back carb and running without the airbox. :( My Dolly will run happily without when needed.
Thank you all for your help, i am now sleeping much better...
Tony
Forkie
#47 Post by Forkie » Sat Mar 02, 2024 3:53 pm
Glad you have finally sorted it :)
Forkie
#48 Post by Forkie » Sat Mar 02, 2024 3:54 pm
Hopefully so will i be able to sleep when my issues are sorted :)
poppyman
#49 Post by poppyman » Sat Mar 02, 2024 5:56 pm
Have you tried yours with and without airbox? mine ran terrible without.
Forkie
#50 Post by Forkie » Sat Mar 02, 2024 6:20 pm
Yes apparently they are un-drivable without. My issue is lack of top end speed. I am fairly sure i have an autobox issue so is booked in for a complete overhaul soon.
