Stromberg / SU adapter
Hello there,
Car - MK1 2000
I’m having problems with my Stromberg’s so want to swap them for the SU’s. I have seen an adapter kit where the SU fits onto the Stromberg manifold but can’t find out where to buy them, anyone know?
Sal
Car - MK1 2000
Sal
Re: Stromberg / SU adapter
Not sure about an adaptor, but IMO the Strombergs are much better built and work very well indeed compared to the similar aged SU.
TR7 inlet manifolds were originally designed for Strombergs but Triumph later fitted SUs by fitting a hard rubber adaptor plate. From memory they are 1.75” diameter, so might not fit a manifold that started with 1.5” SUs.
I have a TR7 manifold in the garage, I’ll measure it and take some pics over the weekend if you want.
I am in agreement with Charles on that one - Strombergs are very easy to work on and to set up - the only issue I've ever had with them is the float valve (needle valve) can leak and allow excess fuel into the float chamber which then enters the air filter box or escapes through the brass link tube into the air intake. This issue is usually down to reproduction / new replacement Zenith valves which don't seem to be manufacturered to the same quality as the originals. Replacing them with good used valves has always cured the problem for me.
I personally would try to remedy the issue with the Strombergs, which, even with a complete overhaul, would be easier than faffing about with inlet manifold adapters, which will also reduce the available space between the carburettors themselves and the suspension turret.
Which SU's are you thinking of using? HS4s, in my opinion, aren't a particularly good carburettor compared with the bottom adjustable Strombergs, or HS6's.
Picture here taken earlier in the year, I’ll measure it up when I have found them in the garage.
Thanks all as always for your comprehensive responses.
Carboy, thanks for the pics but they won’t fit mine.
Update - I removed the Strombergs for the umpteen time and took the jets out, float bowl off and refitted and I seem to have cured all the leaks. I think that maybe something wasn’t sitting/seating correctly.
The only thing I need to do now is set them up correctly. I have unscrewed the jets at the bottom of the carbs and it now sounds sweet but would probably benefits from someone with an air flow meter thing just to double check every thing is balanced correctly.
I have also rectified the oil filter leak. It was a good garage day today!
Sal
Sal
Meant to also say that the only SU’s I have are HS4’s and I’m having a 2.5 engine built so probably need to look around for a good set of HS6’s
If any one knows of any then please do let me know
Sal
Sal
I put this question in the parts section but thought I would ask here too
Is there such a thing as a mk1 inlet manifold for SU’s HS4’s?
Thanks in advance
Sal
Thanks in advance
Sal
Not as standard. From the factory, all Mk1s used CD150s (in one form or another). Of course, specialists may have produced manifolds for other type of carbs but not, as I am aware, from the factory.
ok thanks Mike then that answers my question
So i need to either sort my existing Strombergs or source some better working ones - if anyone knows of any please let me know
Sal
Sal
Users browsing this forum: No registered users and 23 guests
