When removing the old engine mounting rubbers, I noticed a thick (10 mm) spacer plate below them. They do not look original equipment, made of a rectangular steel plate, two holes for passing the bolts. The plates do not appear in the Parts Manual.
I did notice before that the engine mountings looked a bit deformed. I think these plates could well be the cause for this (I have to mount the new rubbers).
What could have been the reason for having these plates? The front of the engine would sit a little higher. Maybe the PO had clearance problems with the fan nearly hitting the radiator? Sump hitting the crossmember?
Ideas anyone?
Dion.
engine mounting spacer?
- Andy Thompson
