I need to modify an early X-Member to take a later style 1-3/4" SU manifold.
Where do I drill the new holes? Can anyone please give me the centre to centre distance new holes to old holes?
I know that the later X-Member has the earlier holes partialy punched. Also am I correct in saying two distance pieces on O/S and none on N/S.
Yes I'm converting the MkII 2000 Estate to take a late 2000TC engine.
Late engine X-Member
Richard
Compulsive PI'er Daughters have Heralds. Son-in-laws have 2.5's
Re: Late engine X-Member
As far as I know cross member is the same, all that's required is to fit the 2 packing pieces on the carb side of the motor between cross member and engine mount. Cheers Tony.
I believe they are different. They are made of 2 parts of sheet steel with both sets of holes in one of the bits, so you can see the extra holes through just one part.
I have drilled one out in the past, but I'm not convinced that the 'marked' holes were in the proper correct place! I think I have an old, rather rusty X-member here so I will try to take some measurements. And yes, you are correct about the packing pieces - 2 on the RH side, none on the other.
To complete this saga, Alex down in Andover very kindly measured the bolt holes on his cross-member. The O/S has the holes as low as they can go. The N/S has the holes as high as they can go whilst allowing the spacer to sit flush.
Engine is in fine and I can remove the air plenum of the SU's as need be.
Thanks all.
Thanks all.
Richard
Users browsing this forum: Bing [Bot] and 8 guests
