Jonathan Lewis
Re: Gearbox/overdrive question #11
Post
by Jonathan Lewis » Thu Feb 11, 2021 10:40 am
Dave B wrote: ↑Wed Feb 10, 2021 4:33 pm
Just to muddy the waters a little, I used to have a pfl M regd (so post August 73) 2.5PI without o/d, and it was original, only 21000 miles when I got it.
The exception that proves the rule?
Perhaps - a possibility that John has already noted - a late registration of a car built sometime earlier? By 1973, BL was having to work at selling its cars and - sadly - Triumph was no exception...
Sal - Senior Member
#12
Post
by Sal » Fri Feb 12, 2021 10:14 pm
Getting a little lost in the technicalities again, not that I’m complaining I’m just learning (not helped by a few ciders on board of course!!!)
But I’m guessing when you speak of A box you mean it’s a manual non overdrive and J is overdrive box, correct?
Cheers Sal
tony - Senior Member
#13
Post
by tony » Sat Feb 13, 2021 3:51 am
A type and J type are both overdrive 'boxes but different models. They do similar jobs but the parts are not interchangeable. Hope this doesn't confuse things further.
johnnydog - Senior Member
#14
Post
by johnnydog » Sat Feb 13, 2021 11:57 am
As Tony says both are overdrive gearboxes but fitted during different eras of production. The A type was fitted to earlier cars, and then from 1973 ish, the J type overdrive was fitted although as discussed the A type was still found in 1974 registered cars. There are relatively minor visual differences, but in driving them, the A type tended to be more of an abrupt engagement, whereas the J type was a smoother engagement.
The other difference between the two was that in the Triumph 2000 /2500 and PI range the reduction ratio in A types was usually 22%, whereas the J type was either 25 or 28%. In other words, in my S, at around 70 mph, engaging the J type overdrive reduces the engine revs by approx 500 rpm. A types can suffer from electrical connection issues to the solenoid as they are exposed and therefore more susceptible to the elements.
There should be a riveted plate on the side of the actual overdrive unit which will identify which type it is.
Charles H - Senior Member
#15
Post
by Charles H » Mon Feb 15, 2021 10:09 am
But Sal will not have that plate, because she says she has a non overdrive gearbox!
wild bill - Senior Member
#16
Post
by wild bill » Mon Feb 15, 2021 6:33 pm
Emmmmmm Charles,
Sal could be a bloke......
Bill Young
1967 MK1 2000 MSS8E
1971 minivan IUI1588
Sal - Senior Member
#17
Post
by Sal » Mon Feb 15, 2021 6:37 pm
I am a bloke!
Sal - Senior Member
#18
Post
by Sal » Mon Feb 15, 2021 6:41 pm
Thanks for all your help guys, I now know I have a none overdrive box, annoying but hey ho onwards and upwards.
On the left hand side of my box (if sitting in the car) there is a slot where I believe the speedo cable goes but nothing is there to attach it to! Is there a gear that attaches to the box that the speedo cable attaches to? What’s its name? And if anyone had a part number that would be great
As always.... many thanks in advance.
Sal (Mr)
#19
Post
by johnnydog » Mon Feb 15, 2021 11:11 pm
Charles H wrote: ↑Mon Feb 15, 2021 10:09 am
Doh! You're right Charles! I must have got in a 'fog' with all the overdrive chat....
#20
Post
by Charles H » Tue Feb 16, 2021 10:11 am
Sal wrote: ↑Mon Feb 15, 2021 6:37 pm
I am a bloke!
Oops, sorry.
