Hi,
Yes, Hi Johny and Alec. Have been away with things for a while but I am back now and still have her; the White Triumph 2000 estate. She runs, has her issues. I'm a better friend to her than she is to me!
I will see what I have on there.
The engine in mine is not the original. It is an MC engine I think, which Johny told me breathed better and was not such a bad thing. So, as this is a rarer engine (I think?), it is not the original according to logbook, however, period as it was used in late Mk1s (unless you know some more which would be welcome) I may have to do some investigating to find out whether the engine actually has the right distributor, which might be something someone may know about? Might be out of a MB?
It's possible someone put a new engine and put the ancillaries from the old one on. It runs far better now the cam has been reprofiled about 100 miles ago by a friend who runs his own business for classic cars. He decided after seeing a bit of black on one of the distributor cap contacts that this would be it. It changed the car. Ran with no lumps. ticked over fine. The tick over has started to waver occasionally now. He had a Triumph 2000 mk1 years ago, which I think he did a bit of racing in. His name is James Boreham. You may know him. One thing thats come to mind (and yours probably), is to just check the distributor cap (which is what I should be doing before posting anything any way shouldn't I).
The car is up at my mums now and with all this lockdown, I can't check all this just yet so I will update you soon.
As for the power spark ones. They therefore might not be compatible across the 2000 range perhaps? There are a lot of electronic ignition distributors on the market, wouldn't want to buy one without a little more information about MC engine.
This is NOS one I have seen on ebay sssh for now eh.
https://www.ebay.co.uk/itm/LUCAS-41450- ... SwKOZcQb6x
They have listed it as Triumph 2000, it it is a 45d6. It gives a serial number no relation to CW listings.
Does anyone know much about MC engines. Is there any data out there?
I have found this:
https://club.triumph.org.uk/menu/5742/item/324525/view
I'll have a search through register posts and see if there is anything.
Jeff
