Warning lights
Choke and handbrake warning lights not working. Everything else does !
Re: Warning lights
If the electrical terminals are still attached to the choke (a bit difficult to check easily as its behind the console) and also on the handbrake lever, I'd twist the chock cable side to side whilst its pulled out to see if it's just a bad connection and similarly wiggle the handbrake whilst applied.
Failing that I'd just try new bulbs. They are probably going to be as old as the car so you can forgive them if they have packed up after 50 years
Re: Warning lights
Have they ever worked, or have they suddenly just packed in?
To test the choke light, you may be able to access the choke switch via the radio aperture (assuming mk2 here) pull the spade connector off and short it to earth with ign on. If the bulbs ok then it should light! Same principle on the handbrake, but more of a faff to get to the switch, which is under the gaiter & carpet on the h/brake lever.
Re: Warning lights
Dave B, the handbrake switch is easy to get to. The gaiter has a velcro opening on the seam for easy access!!
Re: Warning lights
Thank you gentlemen, I will do as you suggest.
