Carb
- Newbie
Can anyone recommend a carb specialist as I think mine could do with a complete strip down and service.
Re: Carb
Whereabouts are you?
What do you think is the problem with yours?
Depending on your abilities of course, there isn't anything particularly difficult in doing it yourself!
Re: Carb
Sorry Anthony - just read your near identical question in the topic 'Carb Service' where you gave your location....not that I can help you any further knowing that, sorry...
With more info about the actual fault with your carbs, others may be able to offer some help or further advice?
- Newbie
Re: Carb
Thanks for your help, I need to replace the rubber fuel lines as they’re beginning to crack, can you advise me as to the best quality I should use?
- Newbie
Re: Carb
Just one more question!!, is there a service kit for Stromberg CD,s ?
- Newbie
Re: Carb
Pps!, is it advisable to do away with the (seemingly) restrictive air filter box and breather pipes in and use individual air filters bolted directly to the carbs ?, if so which ones are the best?, Moss list K&N filters but say they are 3 and a quarter inches deep and I can’t see them having enough room on the front carb. Pancake types would be ok
Re: Carb
There are quite a few options - Chris Witor may do them, although I haven't seen them listed on his website, but others include....Landscape21 wrote: ↑Sun Feb 06, 2022 4:00 pmJust one more question!!, is there a service kit for Stromberg CD,s ?
http://zenithcarb.co.uk/carburettor-kit ... -kits.html
http://www.southerncarbs.co.uk/page_2346185.html
https://classiccarbs.co.uk/product/stromberg-cd150
Re: Carb
If you want to keep the fuel hoses looking original, then most motor factors will sell the black reinforced rubber fuel hose that is resistant to unleaded fuel with ethanol. The reinforced type are less likely to crack or kink. I think you will need 1/4" (6mm) internal bore.Landscape21 wrote: ↑Sun Feb 06, 2022 3:54 pmThanks for your help, I need to replace the rubber fuel lines as they’re beginning to crack, can you advise me as to the best quality I should use?
https://www.chriswitor.com/search.php (although it states for SU, Strombergs are the same ID hose)
Re: Carb
Personally, I have kept the original air filter box with the original style filters on all mine, mainly because I like my cars to look original as intended, and the K&N type just don't look right imho. I've also never been a fan of the 'oiled' type of filters, as they attract dirt, and I think any 'breathing' gains would be marginal, with no noticeable difference in performance. I think they also would create more noise under wide open throttle. As you say, the limited room between the carbs and the suspension turret would reduce any other options. I'd stick with the original personally, but I'm a purist! Depends on how original you want to keep your car, but from your suggested options, I guess this isn't a factor.Landscape21 wrote: ↑Sun Feb 06, 2022 4:11 pmPps!, is it advisable to do away with the (seemingly) restrictive air filter box and breather pipes in and use individual air filters bolted directly to the carbs ?, if so which ones are the best?, Moss list K&N filters but say they are 3 and a quarter inches deep and I can’t see them having enough room on the front carb. Pancake types would be ok
