So further to my earlier post today - got her started up this eve, to nudge up the drive, then reverse back with the O/S closer to wall, to give better access to the N/S, just for testing movement of the N/S/F. ( did contemplate earlier today re putting her back on the skids for ease of moving around) .
So - once better access gained to said N/S/F - all i did this eve was purely jack that wheel up to get a feel for movement - exactly the same as the O/S /F - tightish, wont spin.
So tommorrow's plan is same checks as for the O/S, then up on to the ramps for a visual of the underside, concentrating on the gearbox area
I did assume earlier that as both front corners had exactly the same treatment, at the same time, if one side had developed a fault and the other not, i would of felt a deffinate brake imbalance. Which i havent.
