steering shudder
johnboy
steering shudder
#1 Post by johnboy » Sat Jul 06, 2024 11:23 am
Hi, Was out in Triumph today still a bit of a steering shudder at 45-50 done all the usual checks. but when I touch the brake pedal slightly shudder disappears . Is this a wheel bearing issue? Any ideas? cheers.
Re: steering shudder
#2 Post by Dave B » Sat Jul 06, 2024 9:43 pm
I had similar symptoms on one of my Triumphs a few years back, it turned out to be the ball joint on the track control arm.
I would also check the track rod ends while you're down there!
johnboy
#3 Post by johnboy » Mon Jul 08, 2024 2:29 pm
Its had new track rod ends recently new ball joints in the past couple of years (low miles) I'm wondering if it could be the front shocks? any ideas?
#4 Post by johnnydog » Mon Jul 08, 2024 7:31 pm
Doing the basics first (and least expensive!), have you simply tried swapping both front wheels to the back to see if it still happens?
