Rear Handbrake Cable Mark 2
david_lall
#1 Post by david_lall » Sat Jan 16, 2021 5:44 pm
It's been suggested to me that this parts manual may well be incorrect and that fork on the rear cable should be the same as the fork on the front cable.
So fitting 152251 to the rear cable is incorrect and that actually it should be 154225, the same as on the front cable.
Any thoughts anyone? Perhaps even given how much adjustment there is on the cables it makes no difference anyway.
David Lall
1978 Carlight Casetta Caravan
Re: Rear Handbrake Cable Mark 2
#2 Post by johnnydog » Sat Jan 16, 2021 8:44 pm
The rear handbrake cable that runs between both rear wheels has different 'fork' ends on each side. One is fixed (no adjustment) whilst the other side has the square nut in the fork onto the threaded end of the cable for adjustment. The fork on the fixed end is a shorter fork than the adjustable end. Fortunately, my 1973 PI is over my pit so having checked the hand brake cables, the shorter non adjustable fork is 5cm whilst the other side with the adjustment is 7cm long.
The attachment of the front cable from the handbrake lever to the centre guide is different depending on the age of the car. My 72 and 73 PI's have a bar about 10cm long with a right angle end - the threaded cable connects to the right angle end with a locknut for the adjustment, and the other end of the bar connects to the guide with a clevis pin. However on my 76 S, the front cable from the lever connects to the guide with the adjustment in a fork which is also 7cm long. The latter serms the more logical set up, which is popossibly why it changed on later cars.
Hope that makes some degree of sense!
david_lall
#3 Post by david_lall » Sat Jan 16, 2021 11:07 pm
Yes, that all makes sense and seems to support what's shown in the parts book
David Lall
Jonathan Lewis
#4 Post by Jonathan Lewis » Mon Jan 18, 2021 1:02 pm
If I remember correctly, the right-angled bar was specified for automatic transmission cars, and the forked connector on manual transmission vehicles, at least in the early- to mid-'seventies.
Parts book theory, however, may not necessarily always have been reflected in what was actually fitted! :wink:
#5 Post by Mike Stevens » Tue Jan 19, 2021 12:33 pm
Y'know, that's how I remember it too. So either we're right - or both of us are wrong (as well as the parts book)!
#6 Post by Dave B » Tue Jan 19, 2021 5:04 pm
Having a manual & an auto, I can safely say the auto has the right angled bar 158970 and the manual has the forked clevis 154225.
I assume it is to do with avoiding contact with the propshaft at the gearbox end,
Toyota Avensis TR
#7 Post by johnnydog » Tue Jan 19, 2021 6:08 pm
This all makes sense as it seems autos did have the bar whilst manuals had the fork, although my white manual PI did have the bar setup; maybe for clearance - at the diff end rather than the gearbox end. Having said that, I don't really see that it should make a great deal of difference as the welded cable guide on the transmission tunnel dictates the cables position to clear the propshaft / UJ, and the rear cable has the guides through the subframe box sections. The upturn of the bar is only marginally deeper than a fork, so.....
